1999 E320 fog lights (pic inside)
I need a pair for my E320,i think they cost 180 a pop at the dealer,might as well get after market for half the price and get a pair.
Are those a brand new set or just a really good job of polishing them? I just polished/sanded mine with a cleaning kit and they look good but definitely not as good as yours.
here's a pair for $120.... http://cgi.ebay.com/ebaymotors/98-99...Q5fAccessories .... this is where i got my roof antenna parts, genuine oem, he's prompt with shipping
itself. easily found on ebay as replacements. you can also change to clear lens fogs (versus
OEM fluted lens) but beware that they are Asian aftermarket units. these give the car the
appearance of an upgrade as they give you that pseudo crystal clear look.
If your car did not come with foglights, there should already be holes cut out for them - many cars have the harness already pre-installed, if you look behind the lower part of the front bumper on either side you might be lucky enough to find one. then it is a simple matter of just conneting to new fog lights and installing.
if you don't have a harness already, then you will need to source one and install it - much trickier.
Is your headlight rotator switch which you use to turn on the headlights able to pop out one notch? This is the factory headlight on/off switch.
