Sun Sensor. What is this ???
"Standard Equipment/Interior Features", it list that there is a Sun Sensor.
Exactly where is this sensor located and what does it do?
Gracias....
First: The wiper sensor is not in the rear of the rearview mirror (the rear view mirror sensor is a photocell), the wiper sensor are in the superior, center part of the windsield (you can see a black box back the rearview mirror "thats it"
Second: The sensor in the middle of the dash is the SOLAR RADIATION SESOR for the A/C system, when you get solar radiation directly it turns up the fan speed, close the exterior air flap & set the temp more cold!
Fabio Daniel
Fabio Daniel[/QUOTE]
I did a diagnostics code check via the control unit, and it pulled up a code: (EE1 234) Sun Sensor.
Would a faulty Sun Sensor cause issues in winter while using the heat. Again in the summer I have no problem at all whatsoever with the blower motors function. Just winters. I have replaced the regulator.
Any help would be awesome
Meaning you problem is not related to this code.
not yours, i think you know that.
