Major Electrical components off
Old Jul 10, 2010 | 11:08 PM
Nobsany's Avatar
2009 E320 - 04 E320
I changed the alternator and put a new battery. However, car shows no life. The key turns, but there are lights on instrument cluster, nothing at all. Even headlights and breaklights won't come on. The only things that turns on are the radio and inside lights. I have checked all the fuses (three locations) and they all seem to be alright. What could be wrong? Please help!
Old Jul 11, 2010 | 12:36 AM
ohlord's Avatar
04 E320
you are in the wrong section.
You are a w211
did you replace the secondary battery that is required for starting?
Old Jul 11, 2010 | 04:27 AM
Nobsany's Avatar
2009 E320 - 04 E320
I'm not. I have an E-Class (W210)
Old Jul 11, 2010 | 05:56 AM
raymond g-'s Avatar
99 E320
your profile shows 09 and 04. 210 includes 96-02
Old Jul 11, 2010 | 07:40 AM
Nobsany's Avatar
2009 E320 - 04 E320
The question relates to a 1997, E320
Old Jul 11, 2010 | 11:15 AM
raymond g-'s Avatar
99 E320
oh......we should have been able to figure that out from the start, I guess.
Old Jul 11, 2010 | 03:18 PM
Nobsany's Avatar
2009 E320 - 04 E320
Does anybody have any suggestion as to what could be wrong?
Old Jul 12, 2010 | 06:43 PM
waybomb's Avatar
SL600 r230, SL600 r129, SL500 r230, ML320, C280 Sport, R170 450SL, 190e 2.3 16V (2)
I'd start with - is the battery hooked up + to + and - to -.
Then I'd go check that I had all the alternator connections tight, but disconnect the battery first.
If that's all you messed with. Good luck.
Old Jul 13, 2010 | 12:57 AM
Nobsany's Avatar
2009 E320 - 04 E320
Thanks Waybomb. I have checked all that. I figured out that the last 3 digits on the voltage regulator the parts shop gave to me were different from the original. It took the alternator out and changed it to the right one. Yet nothing happened. Could that be the cause?
I towed the car to my mechanic who thinks their must be a shot somewhere. In his opinion, the ECM should be rules out since even the hazard and headlights are off. He plan to have it towed to an electrician, but I am afraid they will cut my throat for something simple or something they may end up not being able to figure out.
Before you ask me, no code could be read since theirs no power to the steering column or dashboard. Again, battery and alternator have been confirmed good and working
