AC problems
Old Apr 10, 2003 | 05:20 PM
MikeyE430's Avatar
2010 E63 AMG, 2000 E430 Sport, Dodge Charger SRT8
AC problems
OK, gang. This is the second time in a year that the AC failed in my 2000 E430. There was some type of leak and this time they pretty much replaced the drier, compressor, etc. under warranty. The last time it was O-rings and drier.
Does anyone else out there think it is a bit unusual for the air to fail twice in one year in a $57K car?
Has anyone else had these problems? Are there problems/issues with my model year or the W210s as a whole?
Speak to me Forum!
Old Apr 10, 2003 | 10:36 PM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
There's two common problems that stand out in the A/C system of a 210. Number one is the evaporator temperature sensor. When this fails, it reads a false temperature saying the temp inside the evaporator is way too cold, thus reducing the output from the compressor and causing you to have warm air. The second component is the receiver-drier, which either leaks, or internally fails.
Old Apr 11, 2003 | 09:43 AM
MikeyE430's Avatar
Is the receiver/drier a poor design or what? I've owned just about every car from a 57 Chevy, a couple of Camaros, Merkur, Taurus SHO, several Volkswagens, to a Porsche, and including 2 Mercedes and have NEVER had the AC system fail twice in one year.
Is there a long-term fix or do I continue to take it in and have M-B pay to repair it?
Old Apr 23, 2004 | 08:41 PM
T100T's Avatar
Top Answer: 1
2010 E550
How big a job is it to replace the evaporator temperature sensor? Any info on doing this would appreciated.
The car is a '99 E430.
Thanks in advance,
Peter
Old Jun 25, 2005 | 04:10 PM
fast_car's Avatar
1999 E320 / 1988 BMW 635Csi / 1987 Porsche 911 TL Cab Triple Black
Thanks in advance,
Peter
I would like to replace my evaporator temperature sensor, but I do not where is located
Can some one point where to look for
Tan
Old Jul 22, 2005 | 06:24 AM
eLemnt | 0ne's Avatar
AC Schnitzer E46
Me too, I need to know how to fix this as well; I'm having the same problem.
Old Jul 22, 2005 | 03:21 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Tan
Pick Up a New Evap temp sensor...
Remove the Left (DRIVERS) side under dash panel..Have a look towards the center of the car..and You will see it..Very easy to replace..10min MAX!
