sunroof wind deflector problem
There are plastic guides that hold it on each side that probably broke. First, buy new ones (parts.com or your dealer). Remove the old guide from each side and then the deflector will lift out. The new guides should be easy to install and will properly hold the deflector in place and "spring" it up when the sunroof is open.
