Wet floor mat
1. Under right foot of the front seat, driver seat, there is a hole to a duct below the body that wires are coming through it. There was water in there and was wet. There is exactly a similar duct under the passenger side - under the left foot of the seat. The passenger side was dry. I thought there might be a hole or maybe a missing cap on the left side duct, underneath the car; yesterday or the day before it was raining and I certainly drove over waters in pot holes (although I usually try to avoid).
Long story, short; has anyone ever experienced something similar? It was getting dark and I didn't have a chance to have the car lifted; but a quick look - I just bent my knees and looked underneath; it is all covered - not a surprise! Ha!!!!
2. There was a very very thin clear long hose hanging from underneath the driver seat. There is no such a thing underneath the passenger seat. Any idea what is that? I initially though it has something to do with the adjustment. But moving the seat in all possible direction, didn't have any effect on the lenght of the hose.
As I drove the car I noticed sound of water - splashing!!!! I don't know how to describe it, but it sounded as if there is a pool of water and when I hit the break hard, it sounded as if a wave hit the beach!!!! So I took the rear seat out, there was in the battery compartment; there was water all underneath the floor board, much much more on the left side, and less on the right side. There is no evidence of wetness on the right side floor board surface though.
It took me an hour and bunch of towels to dry out the water - though not completely; There are some holes in the body toward the ground for draining; they are not clogged.
Underneath the car, except the drain holes, is all sealed with a kind of tar, resin, ... something like that.
I read somewhere that it might be condensate of the AC. It's way is clogged somewhere, and condensates stay in, rather than going out.
But I don't know where to start ....
Any suggestion is highly appreciated.
All door seals, sunroof seal, window seals .. they are all look perfect!
How can I say if it's old or fresh? It's been underneath the floorboard, definitely not a "clean" spot; but it doesn't smell.
The hose is pretty much in good shape. But there is very thin liner on its outside, and has a pressed line along its length; the press line is not sealed anymore and it leaks.
Have seen many threads on replacing this hose (I don't what's its technical name, or part #) with home-made ones.
... still trying to fix it.
PS: I'll post some pics.
