Charcoal Filters
Old Aug 4, 2010 | 05:12 PM
Palermo Len's Avatar
1999 Mercedes E320 Wagon & 1927 Bugatti Kit Car
Charcoal Filters
I have done a search and have checked the other forum for stickeys and have not been able to locate where these filters are located or how much trouble they are to replace or how often. I know that I have seen something about them in the past but I can't remember exactly where. Will someone please enlighten me?
Old Aug 4, 2010 | 06:15 PM
ohlord's Avatar
it's on
www.benzworld.org
w210 forum
you get them at autohausaz.com
look for cabin filters in your search
shows how to do both types.
easy diy if you follow the directions
Old Aug 4, 2010 | 06:21 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
Hi -
Easy to replace. Above the foot well on the passenger side, remove the black plastic panel. Note: You need to remove the black plastic louver on the side transmission tunnel (1/4 turn of fastener).
After you remove the panel, you can see the chambers. Slide white(?) plastic 'locks' (one up and one down) to remove covers. Filters are inside.
Filters (about $90 a pair) from autohausaz. Originally, the filters were packed with a large amount of act. charcoal and were quite heavy. Newer version is more like a pollen/dust filter with carbon coating. Note one frugal poster opened his old ones and refilled with act. charcoal from pet store.
The only time they come on is if you switch them on or if the sensor detects NOx, SOx, etc.
Old Aug 4, 2010 | 09:47 PM
Javys21's Avatar
01 E320
Then how often are you supossed to changed the filters, if you never use'em.
Old Aug 4, 2010 | 10:11 PM
austinholloman's Avatar
W203 C55 and SAAB 9-3 2.0T
You car will use these on its own so its still a good idea to check them and see what shape they are in.
Old Aug 4, 2010 | 10:23 PM
RichardM98's Avatar
MB recommends changing them every 4 years on W210. If you don't have one, I suggest you pick up a Maintenance Booklet for your MY W210. Just a few dollars (< $10) from dealer or 1-800-FOR MERCedes. There are slight differences from MY to MY within W210. For example, plugs on my MY98 are 100K or 4 years but on the MY01 they are 100K or 5 years.
I changed mine when I got my car about 3 years ago. I probably won't change them again unless I start to use them.
