ABS Light
Old Aug 11, 2010 | 01:09 AM
banker49's Avatar
2001 E320
ABS Light
My ABS Warning light just came on. When the passenger seat is occupied, the light goes off and when it is empty, the light returns. What are my options? Is it a DIY problems or something the stealer needs to repair? Any direction would be appreciated.
Old Aug 11, 2010 | 02:10 AM
ohlord's Avatar
ABS or SRS?
SRS you check the wires to the pass seat occupancy sensor and most likely bad.
Then you replace the occ seat sensor.
Old Aug 11, 2010 | 03:05 PM
banker49's Avatar
2001 E320
SRS
SRS, not ABS. My bad. Thank you for the direction. I'll start examining that area. Is replacing the sensor something that I can do or will I need a more qualified source to perform that repair?
Thank you again,
Old Aug 11, 2010 | 04:11 PM
ohlord's Avatar
DIY
it is a good diy project
www.benzworld.org w210 forum diy section
under 200 bucks and a good mornings work.
