HELP!!!! Too much oil
Old Aug 12, 2010 | 09:38 PM
jluu1286's Avatar
2001 E430
Exclamation HELP!!!! Too much oil
Hey everyone I have a slight problem. I added a little bit too much oil. Is there a way to drain it out just a little bit without doing a normal drain?
Old Aug 12, 2010 | 09:49 PM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
If it's anything under 0.5 quart then I wouldn't worry about it, it's burn off. If it's more then you need to get some out either by draining (good luck with that) or sucking a bit out though the dipstick tube.
Old Aug 12, 2010 | 09:50 PM
jluu1286's Avatar
2001 E430
What do you mean by "sucking a bit out though the dipstick tube.?"
Old Aug 12, 2010 | 09:57 PM
waybomb's Avatar
SL600 r230, SL600 r129, SL500 r230, ML320, C280 Sport, R170 450SL, 190e 2.3 16V (2)
Get a "top sider" or similar vacuum oil remover. Suck some oil out.
ps - that's how you change the oil without ever climbing under the car. Warm the engine up, unscrew the oil filter cover so the filter housing drains into the pan, remove dipstick, stick the topsider tube down the hole, pump up some vacuum, and suck the oil out. Simple.
Old Aug 12, 2010 | 10:06 PM
ohlord's Avatar
How much is a little bit?
Even without a suction evacuation doing it the work shop way,sucking it out....
You can open the filter cap pull the filter and hold it over a drain pan and that will (albeit messily ) get rid of the overage.
Next time DIY
www.peachparts.com resource section diy articles oil change number 2
if you need to learn the easy proper way to do an M112/M113 oil change
jluu1286's Avatar
2001 E430
Is there any other methods to doing this...I just worry it might mess up something with the excess oil. I don't have a vacuum oil remover
Old Aug 12, 2010 | 10:19 PM
ohlord's Avatar
Where are you located?
You can get a hand pump oil transfer pump for a few bucks at harborfreight tools if you have one near you or do like I instructed above.
Old Aug 12, 2010 | 10:25 PM
jluu1286's Avatar
2001 E430
This might sound stupid but what about stick the dip stick in dry it and repeat 129312839012 times lol?
Old Aug 13, 2010 | 01:40 AM
saintz's Avatar
GL450
That will take forever. Get a topsider. It is worth its weight in gold.
http://www.amazon.com/Mityvac-7400-L...1677990&sr=8-1
Old Aug 13, 2010 | 08:55 AM
monsterman75's Avatar
2001 E320 4matic
But what about the paper towels needed, or rags.... I guess Brawny towels will have to step up....
Old Aug 13, 2010 | 09:34 PM
jluu1286's Avatar
2001 E430
Haha you think it would work though?
Old Aug 15, 2010 | 09:26 AM
01BlackE320's Avatar
01 E320
When I bought my E320 I had my mechanic do an oil change (I've done all my own since) and he put in 9 qts of Mobil 1 instead of 8.5 which caused the "too much oil" error. I bought a cheap syphon at an autoparts store and hand syphoned out about a cup, or less of oil and the error went away. I've since bought a topsider and absolutely love it and use it for oil changes on my E320, my 2000 Jeep Grand Cherokee and my boat. Note that it will not work on all engines. Cant get the tube down the dipstick in my 2005 Suburban or a 2008 Jeep Grand Cherokee.
Old Aug 15, 2010 | 12:18 PM
waybomb's Avatar
Also won't work on engines with two sump sections. Well, it work with the one the dipstick goes into.
