mystery drain plug????
Old Sep 19, 2010 | 08:20 PM
mike62's Avatar
2005 E320 4matic wagon
Exclamation mystery drain plug????
Anyone know what this drain screw / plug is? Located just underneath the drain plug for the forward differential. Looks to be about 10mm or so, similar to the oil drain plug at the pan. Changing diff this weekend, discovered this one - what is it???
Old Sep 21, 2010 | 03:03 PM
Ken J's Avatar
w210 E320
Plug
Just a guess because I have never seen the mechanics of a MB 4matic. Most 4 wheel drive systems have between the transmission and the differentials a "transfer case". The transfer case splits the transmission output allowing it to go to both axles. It is generally attached to the output end of the transmission, but it is it's own unit with it's own oil supply.
