Brake fluid flush / change
In the W210 forum check out the DIY sticky for brakes. There are procedures for using a bleeder, how to make your own bleeder and a MB approved manual procedure.
As mentioned, all most all car manufacturers recommend flushing the brake fluid every two years regardless of mileage. Recommended fluid is DOT4+ or DOT 4 LV. The LV is best if you have the ESP option.
