Camber Kit/Bolt Questions
Old Sep 27, 2010 | 03:08 AM
bmroxm5's Avatar
W210 E320
So I went to get new tyres today and when the guy is doing the alignment, we find out the right front wheel has about 2.5degrees of neg camber, while the front left has virtually nothing.
I had the lower control arms replaced recently because I bent one when I had a small low speed hit into the kerb - most likely culprit of the camber issues...
To fix up this camber issue do I need a camber 'kit' or camber 'bolts'?
Something like this from AutohausAZ
or a camber 'kit' like this jobbie from Kmac
My only goal here is to eliminate the camber from the front wheels so they are zero degrees each, or to set them both at an EVEN camber of -1 or -2...
Thanks!
Old Sep 27, 2010 | 03:12 AM
sandro's Avatar
96' E320
Is your car lowered?
If so you may need the Camber bolts.
If not, the problem should be a simple 4 wheel alignment
Old Sep 27, 2010 | 10:54 PM
bmroxm5's Avatar
W210 E320
Yep the car is lowered.
But the issue is that one wheel has some camber and the other doesn't - makes driving in a straight line difficult!
So the camber bolts from autohaus az should be ok? Easy to install?
Old Sep 28, 2010 | 01:15 AM
sandro's Avatar
96' E320
The camber bolts should do the trick
