2001 e320 unhooked battery now have window problems
Any ideas how to fix it or what I did wrong?
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 10"><meta name="Originator" content="Microsoft Word 10"><link rel="File-List" href="file:///C:%5CUsers%5CKaya%5CAppData%5CLocal%5CTemp%5Cmsoht ml1%5C01%5Cclip_filelist.xml"><o:smarttagtype namespaceuri="urn:schemas-microsoft-com:office:smarttags" name="place"></o:smarttagtype><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:ApplyBreakingRules/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:UseFELayout/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if !mso]><object classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui></object> <style> st1\:*{behavior:url(#ieooui) } </style> <![endif]--><style> <!-- /* Font Definitions */ @font-face {font-family:SimSun; panose-1:2 1 6 0 3 1 1 1 1 1; mso-font-alt:宋体; mso-font-charset:134; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:3 680460288 22 0 262145 0;} @font-face {font-family:"\@SimSun"; panose-1:2 1 6 0 3 1 1 1 1 1; mso-font-charset:134; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:3 680460288 22 0 262145 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:SimSun;} @page Section1 {size:8.5in 11.0in; margin:.5in .5in .5in .5in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} /* List Definitions */ @list l0 {mso-list-id:1074081697; mso-list-type:hybrid; mso-list-template-ids:-1696144750 67698703 67698713 67698715 67698703 67698713 67698715 67698703 67698713 67698715;} @list l0:level1 {mso-level-tab-stop:.5in; mso-level-number-position:left; text-indent:-.25in;} @list l1 {mso-list-id:1670791422; mso-list-type:hybrid; mso-list-template-ids:80802614 67698703 67698713 67698715 67698703 67698713 67698715 67698703 67698713 67698715;} @list l1:level1 {mso-level-tab-stop:.5in; mso-level-number-position:left; text-indent:-.25in;} ol {margin-bottom:0in;} ul {margin-bottom:0in;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow
<o:p> </o:p>
To check battery: <o:p></o:p>
- Turn key to position 2
- press and hold REST on CCU for 5 sec
- use L/R AUTO buttons
- toggle to screen 24.<o:p></o:p>
All items that need (or may need) to be synchronized after loss of power (i.e. battery disconnect).
Synchronizing Seats/ Head Restraints:
<o:p> </o:p>
If the power supply was interrupted (battery disconnected or empty), the head restraints are no longer adjusted automatically. To resynchronize the adjustment feature:
- turn electronic key in steering lock to position 2,
- move the seat completely forward and the head restraint fully down
Synchronizing power windows:
If the power supply was interrupted (battery disconnected or low), the windows cannot be opened or
closed by the Express feature. To resynchronize the express feature:
- press <close> side of power window switch to resistance point until the window is completely closed
- hold for additional 2 seconds.
- Repeat procedure for each window.
Synchronizing sliding/pop-up roof:
If the power supply was interrupted (battery disconnected or low), or if the sliding/pop-up roof is blocked during closing/opening procedure, the system has to be synchronized. To do so:
<!--[if !supportLists]-->8. <!--[endif]-->turn electronic key in steering lock to position 2,
<!--[if !supportLists]-->9. <!--[endif]-->move and hold switch in direction (3),
<!--[if !supportLists]-->10. <!--[endif]-->until the sliding/pop-up roof is completely raised at rear,
<!--[if !supportLists]-->11. <!--[endif]-->hold for additional 1 second.
Synchronizing ESP:
If the power supply was interrupted (battery disconnected or empty), the BAS/ESP malfunction
indicator lamp may be illuminated with the engine running.
<!--[if !supportLists]-->12. <!--[endif]-->Turn steering wheel completely to the left and then to the right.
<!--[if !supportLists]-->13. <!--[endif]-->The BAS/ESP malfunction indicator lamp should go out.
Synchronizing remote control:
The remote control may have to be resynchronized, if the vehicle cannot be locked or unlocked. To synchronize:
<!--[if !supportLists]-->14. <!--[endif]-->insert electronic key in steering lock.
<!--[if !supportLists]-->15. <!--[endif]-->The remote control should once again be operational.<o:p></o:p>
