tire pressure gauge
The one I mentioned has a nice shroud on the connector which makes it easy to hold/keep in place on the valve and a rotating connector to position the dial where it's easy to read.
I use factory tire pressures and standard sized tires. I don't try to second guess a bunch of automotive engineers from Sindelfingen.
http://www.longacreracing.com/catalo...id=228&catid=8
You can spend $375, and get memory features and a pyrometer with it, if you really want to get crazy!
http://www.longacreracing.com/catalo...d=1520&catid=8
