Snow tires
Old Oct 29, 2010 | 02:57 PM
nsupra's Avatar
Snow tires
Hi guys,
i have been debating on which snow tires would be ideal for my 430.These are my first winter tires ever. I was originally debating between the Michelin X Ice XI2, and the Continental Extreme Winter Contact, until i was told that they were a T rated tires and that i needed at least an H rated tire because the T rated studless snow tires would burn out very fast because of torque and they would make the car very wobbly and mushy as far as handling goes.
http://www.tirerack.com/tires/tires....odel=X-Ice+Xi2
http://www.tirerack.com/tires/tires....0&autoModClar=
All performance H rated tires are considered performance snow tires which i guess sacrifice some snow traction for everyday use and dry road handling although still better than a all season in snow. I was recommend some H snow rates toyo snowproxes rather than the above mentioned T rated tires.
http://toyotires.com/tire/pattern/snowprox-s952
I really want great snow traction when it snows(which it should at least 5 times), but i also fear of having to replace the tires after 2 seasons. I am really torn between the pro's and con's of a performance vs regular studless snow tire.
Any thoughts, opinions or any input is appreciated
thanks
Old Oct 30, 2010 | 03:12 AM
Lancelot's Avatar
'01 W210 E320 CDI
In my experience, the rear tyres need to be replaced after two seasons...
Old Oct 31, 2010 | 05:26 PM
dsmith's Avatar
88 535is, 89 318iT
I'm getting these (General Altimax):
H rated will hold up to extended driving at 130mph. Do you intend to do that on snow tires? I wouldn't think speed rating is going to matter. They will all be squirmy on dry pavement.
Old Oct 31, 2010 | 10:51 PM
nsupra's Avatar
Thanks a lot no way i would ever want to go that fast. i just thought the Speed rating also played a role in wear as well.
