trans dip stick
Old Nov 6, 2010 | 09:58 AM
gadgetman7's Avatar
1998 Mercedes Benz E 320
trans dip stick
Does any one have information on the length and measurements on the transmission dip stick for a 98 E320?
Attempting to make my own!
I was thinking of using an electrician's snake wire for the dip stick and using a file to make the marks on the dip stick for high and low markings but I need the measurements from the top of the stick from the fill tube ?
gadgetman7
Old Nov 6, 2010 | 11:10 AM
saintz's Avatar
GL450
I tried something similar to this. It didn't work. I finally bought one off eBay (search 722.6 dipstick). Also, Oh Lord on this forum sells them. So does Amazon.
See post #6 here to measure your own.
https://mbworld.org/forums/e-class-w...-dipstick.html
Old Nov 6, 2010 | 11:55 AM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
People have posted a scaled drawing the tip on various sites. Just goggle.
Old Nov 6, 2010 | 06:55 PM
raymond g-'s Avatar
99 E320
just waiting for the espresso machine to fuzz out my latte so i took some pics
the Lowes hardware store gadget is just for comparison. both mic-ed to .25".
surprisingly, the flex was close but the snake was stiffer.
given the slight price diff, not sure why I'd want to go Lowes.
File Type: pdf
Old Nov 6, 2010 | 07:50 PM
nelbur's Avatar
1997 E300D
The length of the Mercedes dip stick is longer than necessary, at least for my car. They all are to be inserted until they hit the bottom of the pan. Using Raymond's close up of the tip, the two marks near the metal portion are the low and high marks when the oil is at running temp.
Old Dec 4, 2010 | 09:09 PM
olivefoto's Avatar
e320 awd
I just used my stick from my sprinter diesel to check the 320. Its too long but I just used some measurements.
Old Dec 4, 2010 | 10:56 PM
RichardM98's Avatar
The transmission oil must be 80+C. Don't go by the coolant gauge in the instrument cluster. If you don't have a way to measure it then drive the car for 30 mins. This is why you need to measure the amount you take out and put the same amount back in. That way the level will be close enough so that you can drive the car before the final check.
Be sure to park the car on level ground before checking the level.
Old Dec 4, 2010 | 11:01 PM
RichardM98's Avatar
When the temp of the transmission fluid is at 80C+ the final level should be in the top band of the dipstick tool. The correct dipstick tool is marked '80 C' at that point. The graduations in the middle of the tool are used to determine how much add. IIRC, each mark is 0.1 liters.
