Engine Oil Disappears
Old Nov 28, 2010 | 07:22 PM
zheka's Avatar
2001 E320
Exclamation Engine Oil Disappears
I asked this question few months ago, but nobody really gave me an answer, cause I didnt know often it disappears.... So heres the story....
Changed my oil not too long ago, car had 112,802 miles
I took my car up north (Florida to Massachusetts), while driving, at around 114,500 miles on it, got the low oil msg. It said to add another 1.0qt. Aaded 1qt, checked again, said OK. continuted driving....
Next gas station I stopped to check the oil, it had 114,787 miles, and it said to add 1qt, but the low oil msg didnt come one... I added another quart, checked oil again, said ok, and continuted driving.....
Got back home to Florida, checked oil at 116,712, it said i needs another quart. Again, the light didnt came on.. Added a quart, checked again, said OK....
The oil doesnt drip anywhere, nor on the bottom, nor on any of the engine components. Dont see ANY drops of oil nowhere, so my assumption it burns the oil...
I am not a mechanic, and dont know how bad the problem is, or in fact what might be the problem. I would appreciate any help where should I begin. Thank you!!
Old Nov 29, 2010 | 12:47 AM
ohlord's Avatar
1qt
every 2k miles is not excessive. 100k plus mile engine going by the rings.
Monitor it monthly by the dipstick and add when needed.
Some engines maintained on fss pass hardly any oil well past 150k miles of life
with 10k oil changes
others go through a few qts between every change.
Don't lose sleep over it.....
Old Nov 29, 2010 | 10:20 AM
Huachipato's Avatar
'04 Cobra & '04 S430
Look at your valve covers as well - I think I'm having a similar issue and I believe mine is due to the valve cover gaskets leaking oil out.
FWIW - my car has 173K miles and seem to add a quart every other month.
Old Nov 29, 2010 | 11:04 AM
saintz's Avatar
GL450
Do you get blue/white smoke when you start the car or when you accelerate quickly? That would indicate burning oil.
Old Nov 29, 2010 | 05:55 PM
zheka's Avatar
2001 E320
Never seen any kind of smoke coming from the exhaust. not white, not blue, not black
Old Dec 12, 2010 | 08:53 AM
punkroder's Avatar
e320s4
Synthetic oil burns clean, no smoke.
Old Dec 12, 2010 | 04:06 PM
nelbur's Avatar
1997 E300D
What weight oil are you using? The thinner oils will burn away faster than the thicker oils. Mercedes recommends oils from 30 wt up to 60 wt, depending on the temperature range the car will see. Older engines with some wear will benefit from thicker oil in general as the oil pressure will be higher.
Old Dec 13, 2010 | 01:48 AM
zheka's Avatar
2001 E320
I put 10w40. I live in Florida. Right now its cold. But in the summer, its always in 90's
Old Dec 13, 2010 | 03:55 PM
elo's Avatar
elo
Your car is perfectly fine. my 01 E430 does the same thing burning oil a bit, it doesn't seem to make a different when changing to different weigh of oil. I switched between mobil1 5w-40 (winter) and 5w-50 (summer) it makes no different at all.
