2000 E430 Double Din conversion - Any done it successfully? or Where to buy TRIM ????
gtrogue's photo. I surrounded the frame I need in red:
If anyone can give the reference and model of that frame it would be much appreciated. I have been searching for that Frame's right size for ages. Thank You
Oh I see. It's a ABS piece to cut and fit as needed. I guess there is no ready made Frame adapters for the w210 double din size out there right? Your HU looks great. What's the model of your Kenwood (can not see clearly in the pic)?
For eg here:
http://www.ebay.com/itm/251356010567...%3AMEBIDX%3AIT
For eg here:
I did not have to do any conversion job as my car is factory equipped with the double din slot (but bigger then standard 2din slots). If my measuring was correct, it has about the same size as the ML 2001-2005 2din slot: 7in 3/8 L x 4in 5/8 W(19cm x 12cm)
Thank you. Yup i still have the car and still building it. Next is the install of the 6 POT brabus front brakes. Stay tuned
