1999 e430 tires
Old Jan 28, 2011 | 12:33 AM
swiderzki's Avatar
1999 e430
1999 e430 tires
Hey guys
my stock tire size is 235/45ZR17. how many more mm do you think i can add onto the tires width wise? do you think i could bump them up to 250mm without interfering with anything? i'm looking to upgrade my tires.
thanks!
Old Jan 28, 2011 | 12:58 AM
ohlord's Avatar
What offsets
on the rims?
A 235 on the fronts is pretty much max
but you could stagger with a 265/40/17 on the rear if trial fit.
Both profiles on 31front and 35 rear ET no problems at all.
Old Feb 1, 2011 | 01:55 AM
blacked210's Avatar
99 Mercedes E320 Sedan
you could maybe try fitting on 245's as i have got those to fit in without having any issues but mine are 16 inch wheels and i run 245/50/16. so you might be able to fit 245/45 in the front and like ohlord said above those 265 on the rear shouldn't be an issue. but make sure nothing rubs and find someone who would be willing to let you test fit tires on , that would be best.
