Replacing tie rod ends. Just one Lemfoerder, or both Pex?
1998 E300 (190K miles) failed inspection for a bad right side tie rod end. I'm going to replace it, and check the rest of the suspension/steering while I'm under there, and then get it aligned, but ran into a parts question.
AutohausAZ only has the right side in Lemfoerder and has the left only in Pex brand. I'm wondering what the forum's wisdom is on if I should replace the left one now (betting that a new Pex is better than the existing, tests-OK, one).
Cost of the parts is no issue for me; I'd rather not have to get an alignment twice in a short time frame (time/hassle factor and cost). Doing the work myself.
Thanks for any advice,
--Jim
--Jim
r/r
both with both brands and get it aligned once. Replace your drop link bushings and examine b joints while doing the job. Mark the trods with a ref point to get close for your drive to the dealers hunter machine.
If you want both the same brand call az or check with the guys at www.peachparts.com
