short squeel noise
Old May 4, 2011 | 07:56 PM
mike430sport's Avatar
2000 E430 Sport
short squeel noise
I hear a short squeal noise after I turn the car off . what could it be
Old May 4, 2011 | 08:47 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
Might be the serpentine belt or one of the various accessory pulleys. Try listening with the hood open while someone starts/stops engine.
Old May 5, 2011 | 12:09 AM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
+1 serpentine belt is slipping and causing the squeal. Check or replace belt and /or belt tensioner.
Old May 5, 2011 | 01:09 AM
2000 E430 Sport
I replaced the serpentine belt about 6 months ago. It's a slight squeal, very short sound when engine shuts off. I will try to pinpoint the sound tomorrow. It sounds like its coming from the front passenger side.
Old May 5, 2011 | 03:21 AM
desired_speeds's Avatar
2007 SL55 AMG
when was the last time your belt pulley were replaced?
Old May 5, 2011 | 10:36 AM
2000 E430 Sport
Idler pulley 2 yrs ago.
Old May 5, 2011 | 11:14 AM
RichardM98's Avatar
If you have a mechanics stethoscope, you can listen to each of the pulleys on the front of the engine. If one is failing, chances are it will make a little noise while running although maybe not enough to hear it by ear over the fan/engine noises. BTW, the stethoscopes are pretty cheap at auto parts stores.
Unfortunately, even a year old part can fail. Unlikely but no guarantee.
