Rain sensing wipers not working
Old Jun 1, 2011 | 09:31 AM
khalilnasser's Avatar
c240
rain sensor is a very delicate sensor it have to be positioned well in the windscreen with the perfect degree and mounted on the windshield with a special gel only MB company's have and the UV light of the sensor have to be regulated using a star prog. and the position between the sensor and the windshield have to be exact . only mb certified know this information .
Old Jun 1, 2011 | 10:34 AM
mwakabaga's Avatar
E200(210) 2000
Well, but the nature of problem is strange some how,coz sometimes wiper can work fine but on other hand if i switch Pos 1 the wiper doesn't stop till i switch OFF the car and switch Pos 0,and wiper can stop anywhere (center,middle or other side of windscreen ).
Pos 2 and 3 switched the wiper remain ON ,no matter i switch to Pos 0, unless i switch off the car and turn to pis 0.(In short i can switch OFF the wiper Pos 0 but still wiper its ON) So you still suggest the Sensor?
Old Jun 2, 2011 | 02:29 AM
c240
no not the sensor i think it's the wsitcher of the wiper i think he's damaged because when you put it oh any position it worked fine but if you put it on the 0 position i did not triggered any event on the car computer, but you turn off the car and then on the computer have to check if he found it on 0 position he turn off the car.
NB: i think if the computer it self is damaged a light have to be on on your dash board!!
Old Jun 27, 2011 | 04:09 PM
mwakabaga's Avatar
E200(210) 2000
AC_E200
Hi,facing problem of Aircondition,i refill the gas,the compressor tend to work but inside still hot air coming but sometimes cold air coming then stops ,as if when compressor gets hot then hot air starts to come inside,if i park the car and remain silence the Cold air starts to flow but once i starts to move then turn hot air again.
anyone can assist on this matter?
thanks in advance.
Old Jul 12, 2011 | 09:03 PM
gorgerider's Avatar
2000 clk 320 cabriolet
Thanks for the pics and write up. I've been looking for the last two days on this forum for exactly this so I can replace the comb. switch on my 2000 CLK 320. I've had the part for a year, but not the guts to go digging into it.
Gotta love this site.
Old Jul 17, 2011 | 03:17 PM
Iamthephoenix's Avatar
1999 e320 4matic
if you wanted to add rain sensing to your ride, could it be done & where would one order the parts?
  #32
1999 e320 4matic
Old Jul 18, 2011 | 11:50 PM
  #33
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
Originally Posted by Iamthephoenix
If you wanted to add rain sensing to your ride, could it be done & where would one order the parts?
You should have started a new thread for this as it is not pertinent to a thread about non-working rain sensing wipers.
But to answer your question, anything is possible if you have the patience and enough money for the parts. You'll need (at the minimum) a different combo switch, windshield and the rain sensor. Then the car will need to be programmed with an Star so it will recognize the new feature. There might be more but I think you get the idea. Not worth it in my opinion.
Old Jun 23, 2012 | 01:53 PM
  #34
Watchcame430's Avatar
Mercedes E430
Hi all ... Accept this is an old post but it has some relevence.
My rain sensor has dropped off ( the black wired cover, not the bit stuck to the window) .... Mercedes replaced the winscreen a couple of years ago and looks like they didnt stick it on very well.
I notice above mercedes are meant to have the secret of re applying, but has anyone had any luck using a product available in stores?
Halfords have a glass glue, but its glass to glass or metal to glass.
Any products reommended? Thx
