alternator/battery visit workshop message
Old May 24, 2011 | 10:10 AM
juve010's Avatar
e320 4matic wagon
Driving home last night, lights on, A/C, received this message in the cluster LCD. Pretty sure the battery is somewhat new (1 year old) so can I assume its the voltage regulator? I did check to see that the poly belt is still on all the pulleys.
Old May 24, 2011 | 10:16 AM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
Since you are only "pretty sure" about the battery age I'd check that before buying a VR. It still might be bad.
Old May 24, 2011 | 10:21 AM
juve010's Avatar
e320 4matic wagon
OK, good call. I'll try and replace it later today.
Old May 24, 2011 | 10:26 AM
Musikmann's Avatar
It might be better to have it tested first.
Old May 24, 2011 | 10:28 AM
juve010's Avatar
e320 4matic wagon
OK, to test it, do they hook up their machine directly to the battery underneath the rear seat (wagon) or are there points under the hood? Reason I ask is I have to remove the baby car seat if they need access to under seat.
Old May 24, 2011 | 10:37 AM
Musikmann's Avatar
Not sure here but it seems like putting their tester directly on the battery terminals would be more accurate than using the jumper posts. You can also do it yourself using the CC diagnostic feature. Sorry but I don't have ready access to the steps required but it's a piece of cake.
Old May 26, 2011 | 09:10 PM
juve010's Avatar
e320 4matic wagon
UPDATE:
Well, went ahead and replaced the alternator with my dad's help. Turns out there are two, Valeo and Bosch units. I had the Valeo which turns out Napa wanted to r$#pe me on price with $299!!!! Went to Autozone paid less than half that and am happy to report it solved the problem.
So for others with this problem if you DIY the replacement, make sure you get the right alternator!
