Tensioner belt
Old Jun 3, 2011 | 03:18 PM
tigerlee's Avatar
1999 E320
Tensioner belt
Hi all
I have 99 E320, how do I replace the tensioner belt, my have a torx crew inside, is it the new one or old syte. if I replace the belt, how do I know when the belt is tight or loose.
Thank you very much
Old Jun 3, 2011 | 03:47 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
Are trying to replace the serpentine belt or the belt tensioner? Tension is automatic.
The belt is replaced by rotating the tensioner and inserting something like a 5mm drift to hold it open. Then remove old belt and replace. Should be a diagram of the routing under the hood and in the owners manual. Same belt comes in different lengths so be sure to get correct one.
There is a good DIY on tensioner replacement on benzworld
http://www.benzworld.org/forums/w210...ml#post2929658
It's also discussed several times on this forum. Check forum search.
