Wipers/indicators/etc not working - fuses/relay question
Old Jul 30, 2011 | 05:46 AM
philv's Avatar
w210 e class 2001 estate 320 cdi auto elegance
Hi,
i had the heater blower regulator go.
It took otu some fuses as well.
I have disconnected the regulator and ordered a new part.
I have replaced fuses 4 and 7 to get dash board/clocks back.
Now the wipers, the indicators and the flasher for central lookign don't work.
I have looked at the fuse card and it seems to be fuse 41?
From what i have read on here there is no fuses 41
I have rea don here that it coudl be fuse 5 under the bonnet?
Or should that be under the rear seat?
First of all coudl soemone explain why there are no fuses 41 to 44?
Also, if fuse 5 looks ok, i have read that it coudl be the relay.
Now......i have a right hand drive car, so where exactly is the relay?
If the fuse 5 is ok and i have to change the relay, is this easy?
Is it just -
disconnect battery, pull relay, put in new one, reconnect battery?
And which is the wiper/indicator relay ?
Sorry for the questions.
Have a nice weekend,
Phil.
(merc w210 2001 e320 cdi auto estate elegance)
Old Jul 30, 2011 | 12:11 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
You should have one I think. Several circuits are tied to it. See red arrow at the rear of the fuse panel image.
Attached Thumbnails Wipers/indicators/etc not working - fuses/relay question-fusepanel01.jpg
Old Aug 5, 2011 | 07:19 AM
philv's Avatar
Thanks for the reply.
I found the fuses. The numbering was fainter and i missed them.
In the end it was the heater blower regulator/resistor.
It had 'melted' and caused fuses to go.
Replaced he fuses and the regulator and that now works.
