2001 E430 Tranny is popping
Thanks in advance for your help
Heres a link to the d.i.y
http://www.benzworld.org/forums/w210...ion-fluid.html
Be sure to read the whole post for more knowledge about tranny fluid, cool videos on page 32 also
Since there is no drain plug on your torque convertor you need to use an fluid exchanger to get all of it out.
You might also check the electrical connection on the side of the trans for the source of the leak. It's common for the o-rings to fail.
Well it was until my front wheel bearings started going out.
