AMG Wheels Fitting.....
Old Jun 3, 2003 | 09:43 PM
YENPINGW's Avatar
CLK 430
Hi,
Does anyone know if the AMG SL 2PC whill fit on the 99 E430 with any modification ?? The spec for this wheel is 18x8.5ET25 and 18x10ET25. What is widest tire size I can use without robbing problems??? Please advise, Thanks in advance....
Old Jun 4, 2003 | 11:38 AM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Re: AMG Wheels Fitting.....
Originally posted by YENPINGW
Hi,
You might try posting this thread in the "Wheels & Tires" forum or maybe just ask Luke from Tirerack directly and see what he says.
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
They will require some modification to use. The warning in my AMG W210 listing says:
"Required front & rear fender rolling, bump stop kit and fender spacker kit"
I have also heard that some guys have the offset 'shaved' back to 35mm offset.
Tires:
235/40/18
265/35/18 rear
Old Jun 4, 2003 | 05:33 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Tires:
235/40/18
265/35/18 rear
I don't think you can shave those wheels down to ET35. I am pretty sure that the max allowable is ET31, which is pretty close... close enough to work on the W210 (and look pretty agressive).
But AMG has become fairly aggressive in their fitments lately... I've seen a W209 in Affalterbach with SL wheels, which looked pretty aggressive too!
-s-
