Car does not rev well past 4500 on 3/4 to full throttle
Old Sep 20, 2011 | 10:10 AM
jlee240's Avatar
e240 1999
Hello Folks,
just joined the forum. looking forward to participating.
I have a 1999 e240 petrol autobox. to date has only done 73,000 kms and still runs sweet.
It has an auto box and drove it slowly for a while. recently using kickdown on full throttle to the floor it appears to rev fine from tickover to around 4,500 rpm but then stays there at 4,500 rpm and holds the gear. it really feels "choked" (like it is not getting enough air into the engine) and does/will not really rev past this point on 3/4 to full throttle. however, if you lift off a tad, to about half throttle, it then changes up and continues going as normal.
if you use half to 3/4 throttle from rest it will keep accelerating without this "choking" feeling and and changes as normal and will rev past 4500 rpm nearer to redline. SO, it DOES rev to the redline but not on 3/4 to full throttle.
any help appreciated !
Cheers
Jlee
Old Oct 7, 2011 | 09:48 AM
jlee240's Avatar
e240 1999
no one ????
Old Oct 7, 2011 | 11:07 PM
E320User's Avatar
Black 2000 E320 4Matic
Sorry I'd like to help you but I don't have any idea on this topic
Maybe try a transmission flush?
Old Dec 13, 2011 | 04:28 AM
SoutieRSA's Avatar
1999 E240 Elegance
Greetings,
I'm not any sort of expert, however, I would start my search at the throttle position sensor (if that is the right name). This is the sensor that determines the position of the accelerator pedal. If you have a look under the bonnet, on the right-handside, towards the windscreen, you'll see a black, round plastic "thing" with a cable attached to it, with the cable dissapearing into the cabin.
I suspect that the unit is failing, resulting in the car's ECU going into a "fail-safe" mode. Is the problem consistent, or does it clear if you switch off, and re-start the car?
Else, it could possibly be the Mass Air Sensor that is failing, resulting in the fuel injection not delivering the correct amount of fuel, thereby "smothering" the motor.
Anyone else? Please correct me if I'm wrong...
Old Dec 14, 2011 | 04:21 AM
13bArtillery107's Avatar
2000 e430 4matic
I had a similar issue which i solved by removing the rear cat and muffler, the inside of the cat blew into the muffler and was clogging my exhaust and choking the engine, try disconnecting your exhaust and take it for a testdrive. If that fixes it you know what's wrong.
Old Dec 19, 2011 | 12:42 PM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
You do not mention if you are in gear and cruising down the highway when revving or sitting stationary. If it is the latter it is a function of MB safety protocol that the engine will not over rev without a load attached namely the transmission engaged. My w124, W210 and W211 all operate that way.
Old Dec 23, 2011 | 08:36 AM
jlee240's Avatar
e240 1999
been away. just got back.
car is in gear and cruising.
Funny thing is that after i got a new key copied for the car, the car ran perfectly and had no hesitation at all. perhaps due to the battery being disconnected for a while as other work was being done on airbag or the ecu resetting itself with no power and the ecu learning new style driving pattern. also get lots of traffic jams here.
the issue has slowly returned and the rpm at which it does not rev well has slowly declined from being able to redline to 500 rpm increments over the past 5-6 weeks and now back to how it was.
So question is:
A. did the battery disconnection reset something to allow it to rev well and has slowly declined back to normal after traffic jam style driving
B. if so, how can i reset the ECU (without disconecting the battery) to re-learn the non grandad driving style that seems to be ingrained now.
I googled this and found the following procedure to reset ECU on MB cars but does not work on my MB e240 1999 petrol auto. maybe another procedure?
The procedure to reset the ECU is as follows;
"1. Turn the igniiton key to the "on" position which is just before you crank
the engine to start.
2. Press the accelerator to the floor and hold for 5 seconds.
3. Then turn the key to the off position but do not remove the key, then
release the accelerator.
4. Wait at least 2 minutes, the ECU is then reset.
5. ECU is now reset .
thanks folks
Old Dec 23, 2011 | 11:23 AM
saintz's Avatar
GL450
Sounds like a bad TPS. See if this is your problem:
https://mbworld.org/forums/w210-amg/...hrottle-2.html
Old Dec 23, 2011 | 05:53 PM
jlee240's Avatar
e240 1999
Saints, thanks for the reply. Nah, car still works fine and will still go into kickdown and drives as normal. Cruise control ok. Just does not seem to rev well. Easing off the throttle to drop revs below 4500 rpm and car accelerates okay until it changes up gear and continues onward and upwards.
Just does not seem to like revving past. 4500 rpm on kickdown. It ran great after battery off and the kickdown rev limit seems to have creeped downwards more and more as I drove it over a period of 6 weeks or so until back to the state of my initial post. Weird! Need enlightened on this weird problem. Bad spark plugs ? Mag ? No clue but wanted to try an ecu reset to rule out anything broken first. Make sense ? Cheers
Old Dec 27, 2011 | 02:59 AM
jlee240's Avatar
e240 1999
Anyone know how to do ecu reset on e240 petrol 1999 without disconnecting the battery? Not sure if I can disconnect the battery without havin to recalibraye other stuff on the car, electric windows, power steering column, abs etc. sorry bit clueless about the e240
Old Jan 1, 2012 | 09:12 PM
fabbrisd's Avatar
You are chasing the wrong direction - you have to get at the cause of the problem - and not just reset your way around the car because it is trying to protect itself (and you) against additional damage.
You need to see ohlord's reply to you and act on it...
Old Jan 2, 2012 | 03:50 PM
ESTJ's Avatar
2001 E55 AMG - 2001 E320 - 1990 300CE
Fuel filter or exhaust system??
Old Feb 23, 2012 | 09:11 PM
jlee240's Avatar
e240 1999
not been using the car much but wanted to get this fixed as its bugging me.
UPDATE:
1.Have replaced the non standard fuel filter for original fuel filter (someone said that sometimes the non original restrict fuel pressure so may cause this effect)
RESULT - no change.
then
2. changed the fuel pump (was a litle noisy and had a small leak)
RESULT - no effect but had to be changed anyway
3. changed the mass air sensor (fault code showed)
RESULT - car does rev better and up to redline but car defintley still shows hesitation during the rev range from 4000 upwards but does rev past 4000 now. its like being starved of fuel
Fault codes cleared on the air mass meter but there is one code still showing now whic is "61A" but dont know what this code means. anyone help ?
car is 1999 e240 petrol v6 2.4 litre automatic slushbox.
Cheers
Old Feb 24, 2012 | 04:10 AM
2000 e430 4matic
Have you
looked into the exhaust choking the engine? This sounds exactly like the issue I was previously having. What error codes show up?
Old Feb 24, 2012 | 04:34 AM
jlee240's Avatar
e240 1999
you mean the catalytic converters or something are blocked? confused although that does not take a lot to confuse me ? LOL
fault code was 61A
Old Feb 25, 2012 | 09:50 PM
2000 e430 4matic
Yes
that's what I was referring to. I had the insides cat blow out and clog up my muffler, The cat was hollow, the muffler was plugged. Either way you can check to see if either makes a difference by disconnecting the exhaust near the front. There's a spot where you can just take off the bolts near the front of the car. There's easy access, I didn't even have to jack my car up. You may or may not have to depending on your size It should take a half hour to an hour maximum to disconnect the exhaust, and after your done take it for a test drive and see if it makes any difference!
Old Mar 6, 2012 | 03:38 AM
jlee240's Avatar
e240 1999
Reset the codes. Added in some fuel injector cleaner and running fantastically ! Finally
