2002 E320 Brake pedal travel..
Old Oct 16, 2011 | 12:40 PM
dwongsam's Avatar
e320
Question 2002 E320 Brake pedal travel..
2002 E320 brake pedal goes down near to the floor when braking. car stops, I think the pedal travel is too great. Front and rear pads are are only 10% worn. Only 5000 miles on pads...Thanks for any help with this problem...
D.Wongsam
Last edited by dwongsam; Oct 16, 2011 at 12:44 PM. Reason: did not specify problem
Old Oct 16, 2011 | 02:33 PM
maxwerks's Avatar
06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
sounds like Brake Fluid issue .. when was the last time you flushed the brake fluid and did a good bleeding .. I would do that first ...
Old Oct 16, 2011 | 09:02 PM
Fabio D's Avatar
210 55
You need a goooddd power bleeder bleed the system and your problem are solved for sure you have some air in the brake lines
Fabio Daniel
