headlamp "downgrade"
Old Oct 26, 2011 | 04:42 PM
Elvis_Presley's Avatar
buying an e320 wagon
Want to switch out my xenons for halogens. looking at some used xenons and need to decide quickly.
Can anybody tell me if they will just plug right in, or if there is difficult wiring involved?
My car is a 2002 w210 wagon with xenons
My plan is to switch to 65 watt halogens, then ebay the xenons. I know a lot of people like them--i'm just not one of them.
Old Oct 26, 2011 | 04:51 PM
also, will the leveling feature still work if i swap out the headlights
Old Oct 26, 2011 | 10:30 PM
raymond g-'s Avatar
99 E320
the difference between the HID v halogen headlight assembly/shell is that HID
has the linkages for leveling telemetry whereas the halogens do not.
if you want autoleveling, you're going to have to perform some serious retrofitting.
otherwise, a fairly basic swap out of assemblies should do the trick, though,
you will have leftover linkages which go unused (same with electrical).
you had indicated (on Bworld) that you prefer yellowish light. have you tried to
shop around to see if you could locate an HID bulb with lower Kº, e.g. in the
3500-4000 range? I dont know if they exist but i know that with the D2S model
there are variations on a theme of bulbs with varying temperature hues.
Old Oct 26, 2011 | 10:54 PM
MBFLO's Avatar
2001 E55 - 2008 CLS63 -2016 F-150
what he saying would be your best bet will be bright and give the halogen effect
Old Oct 27, 2011 | 01:04 PM
Fabio D's Avatar
210 55
Why you want that? :S i know xenons are expensive.. but is real downgrade pass from xenon to halogen
Fabio Daniel
Old Oct 27, 2011 | 04:53 PM
I haven't driven the car at night--and my lenses need polishing or replacing. So maybe I will find that the xenons are a lot better. In the meantime, i bought some used oem halogens for 50 including shipping). So i will try to put more the better lenses on my car and if i like xenons better, i'll let you know!
Anyone know how much more light output xenons give? I know you can easily upgrade halogen to 65w and get 20 percent more output. And yellow light is better at night. FYI: if you are looking at a field of flowers at dusk, that last ones that will be visible before it gets dark are the daisys. This is the same reason lighting bugs' light is yellow.
Old Oct 27, 2011 | 06:14 PM
raymond g-'s Avatar
99 E320
measured in lumens....memory recalls about 2x improvement D2R vs halogen,
and 3x if D2S
Old Oct 27, 2011 | 08:22 PM
I've sen those numbers on site selling HID bulbs and kits, but is there a more objective source. Also, on my 2002 wagon, do i have D2R or D2S?
Old Nov 2, 2011 | 03:38 AM
desired_speeds's Avatar
2007 SL55 AMG
d2r
Old Nov 2, 2011 | 08:57 PM
raymond g-'s Avatar
99 E320
well, i suppose you can use keywords "lumens" and "D2R".....also D2S and h7
and gauge for yourself. but use of lumens to compare is quite consistent and
pretty reliable
