1997 E-420 Firing Sequence needed....
Old Nov 23, 2011 | 03:30 PM
KBE's Avatar
KBE
Mercedes Benz E-420 Sport
Cool 1997 E-420 Firing Sequence needed....
Any help here would be appreciated. Could someone please confirm the firing order for a 1997 E-420? I think that it is 1234 front to back on passenger side, & 5678 front to back on driver's side, but I want to be absolutley positive of this before I replace the coil pack on cylinder "8". Please help & thanks!
Old Nov 23, 2011 | 05:10 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
Hi and Welcome -
If you want the cylinder numbers then you are correct. Left (drivers in US) side front to back is #5-#8, right side is #1-#4. However, this is not the firing order which refers to the sequence. The order is 1-5-4-8-6-3-7-2
Old Dec 1, 2011 | 01:27 PM
KBE's Avatar
KBE
1997 E-420 fuel injector question...
Thanks for your reply on the firing order. I appreciate it. One more question if you don't mind. One of my fuel injectors is leaking, so I was going to replace the "O" rings on all 8 since I'm going to have the entire rail free. Do you have any advice for carefully removing and replacing?
Thanks!
Old Dec 3, 2011 | 09:25 AM
RichardM98's Avatar
Sorry for not responding soon. I've been in the middle of the SoCal power outage.
I haven't had to perform any service on my injectors which I attribute to burning only Chevron (? ). You might want to look at the stickies for maintenance DIY here, at benzworld and at peachparts for any details.
