Driver Side Mirror Oil Stain
Old Dec 17, 2011 | 11:18 AM
ccozic's Avatar
1998 E320 Wagon 253K miles
My driver side mirror glass reflection gradually grew cloudier, from top of glass downward.
When the mirror fails, the oil inside that is used for heating the mirror glass can leak after a rainshower, or after hose-washing your car.
NOT GOOD!
This oil dripped down a long thin line down the side of my door.
This stuff is as bad or worse than sap or road tar.
Not to fear. After reading online about various methods to remove gunk from body paint, I figured I would try WD-40 and a microfiber towel.
It works! It doesn't come off right away, not by a long-shot. It took me about 20 minutes and a couple dozen sprays to remove the foot-long stain. No harm to paint or clear-coat either.
At very close-up, there is a trace of residue left. I will get a clay bar to get the rest off.
Now I have to figure out how much -- if any -- of this oil is still inside my mirror. Then order a replacement glass, of course.
Old Dec 17, 2011 | 12:08 PM
nelbur's Avatar
1997 E300D
What you call oil is likely the liquid crystal goo that does the auto dimming on the auto dimming mirrors. The mirror glass is actually a silvered glass, a layer of liquid crystal goo, and a cover glass. It is common for the liquid crystal to fail by become rather dark tinted even when you don't want any dimming. If the goo leaks out you should be able to see a horizontal line in the mirror where the top of the goo is. If it has all leaked out, you will not have auto dimming, and the heat might not conduct well to the cover glass, but if you can still see well with the mirror, you are lucky because auto dimming replacement glass is big dollars.
Old Dec 18, 2011 | 12:33 AM
ccozic's Avatar
Yes, the horizontal line is about 2/3rds the way down the glass right now.
Old Dec 20, 2011 | 07:34 AM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
My dealer wanted $675 for new glass so I bought one from AutohausAZ for roughly 1/2 of that. Replacing it is a piece of cake.
Old Dec 20, 2011 | 07:52 AM
yeldogt's Avatar
88 560 , 02 E320 wagon
Yes ..... that is the dimming liquid crystal oozing out -- need to replace the glass. The facelift mirror is very expensive - that price from AH is very good.
The pre-facelift mirror glass is much cheaper
