...side mirror glass fell out.
'12 Cayenne Turbo, '12 GL450, '03 SL55, '89 560SL,
I hit a pot hole... and
The glass in my passenger's side mirror fell out. It's hanging on by the wires, but I can't seem to "pop" it back into the housing. What's the trick?
<--- It's a '98 E320.
Thanks, peeps!
Thanks, peeps!
Look through the DIY section(outer mirror repair), you need to remove the outer housing(fold the mirror, and using a flat screw-driver pull the tab and the cover will slide right off, all instructins are in the DIY), On the glass you should have a straight piece of wire, un-hook it from the glass upwards, leaving one side attached, then clip it onto the motor, and install the wire, making sure that it hooks onto the small tub, sticking out of the motor base, then slide the Outer cover back on, you're done!
Good luck.
Good luck.
