Fixed Po 715 Still Stuck in Limp Mode
Old Feb 22, 2012 | 07:17 AM
sphillipsmith's Avatar
1997 E320
Red face Fixed Po 715 Still Stuck in Limp Mode
Just joined the forum although I have been reading. I had a mechanic fix the PO 715 code by changing the plate and fluids. The car is still stuck in limp mode althought the light check engine light went out. Is there any programing involved at this point or what should be my next step? MB Service center???? Trying to avoid the extra costs.
Signed
Rookie
Old Feb 22, 2012 | 07:20 AM
1997 E320
You can also add to my email address when you respond sphillipsmith@msn.com I would appreciate it
Old Feb 22, 2012 | 10:29 AM
ohlord's Avatar
Yes
if that was the issue resolved with the input output speed turbine ,etc, and the code cel is clear you will need to get it on an sds and have the code cleared. Then it will leave limp mode.
Did you replace the electrical connector and o ring to make sure it was not leaking?
