rear deck removal
Old Mar 28, 2012 | 11:53 PM
mrgoodcat66's Avatar
2002 clk320
rear deck removal
Does anyone have a good step by step guide or DIY video to remove the rear deck that sits behind the rear seats? I want to replace the rear speakers. Thanks in advance!!
Old Mar 29, 2012 | 08:22 PM
Fabio D's Avatar
210 55
No need to remove the rear deck to replace the speakers, just press the clips of the speaker by the trunk, remove the covers from inside the car and you can remove the speakers (is not very very easy, but Yes, is possible)
Fabio Daniel
Old Mar 29, 2012 | 09:41 PM
CKonstantin's Avatar
W210 E300D
Try Fabio's way first, otherwise you have to remove the rear seat(upper and lower) then Head-rests and C pillar trims. If you decide to remove it all I can provide the step by step, no video though. It's pretty straigh forward, trims ar clipped on and seat is bolt on, the tricky part is the headrests....
Good luck.
Old Mar 29, 2012 | 10:14 PM
2002 clk320
Thanks for the help guys! this weekend I will try and just pop them out the easy way. If I cant get them in I will ask for the step by step. Also I'm trying to install aftermarket speakers. Will the easy way still work? thanks again guys!
