Plz Help "Do it yourself"
Old Jul 5, 2003 | 11:49 PM
Merc1's Avatar
1998 E320
Hi to all,
I have been browsing this board for a while, and found this board to be very useful and it seems everyone is trying to help each other out.
If anyone can give DETAILS on the following, it would be greatly appreciated.
I just bought 1998 E-320 with 73000 Miles on it. I cant find record as to what service has been performed on it. I am thinking about doing everything to the car.
1.My qustion is Exactly what needs to be done upto and at 73000 Miles?
2.I am in Arizona, it reaches 115 degrees here, But its Dry heat What type and weight motor oil I should use?
3.Also, along with service you all recommend, should I do differntial oil change and what brand and weight.
4. Power moon roof opens only little and it stops, and makes noises, however tilt works fine. I use tilt switch to close moonroof back. I believe there are 2 cables. What do you think needs changing.
Please send details here or to my e mail PRONEXTSOLUTIONS@HOTMAIL.COM
Thanks in advance for your help and replies.
GOD BLESS
Old Jul 6, 2003 | 01:37 AM
E430 George's Avatar
1999 E430
Re: Plz Help "Do it yourself"
I am not sure about your other questions, but I had a similar problem with my moonroof, the dealer repaired it under warranty so I am not sure what they did, but when I asked them they told me all they did is lubricate the railings.
Also, if while trying to open the moonroof it opens a little then you have to let go of the button and press it again to open it more; it might be that at one point the previous owners battery died and he never reset the moonroof after jumping, try closing the moonroof using the tilt function, when closed hold the button down in close position for about 15seconds, I was told by the MB dealers that this resets the moonroof.
Hopes this helps, but in case good luck and congratulations with your purchase.
Old Jul 6, 2003 | 12:34 PM
Merc1's Avatar
1998 E320
Moonroof
Thanks,
I will try it. My main concern was making NOISE, and it wont open further. I thought cable may of been broken. ANY HELP WOULD BE GREATLY APPRECIATED.
Old Jul 6, 2003 | 01:19 PM
Benz's Avatar
2000 F-150 XLT Sport Crew Cab
mobile 1 synthetic oil !
Old Jul 6, 2003 | 02:21 PM
Randy B's Avatar
**SOLD***2003 E500
Merc 1, go to Alldata.com and sign up for your year model MB. It will cost you about $15.00 a year, and is priceless when asking questions like what you have. The diagrams and step by step instructions are well worth it.
Old Jul 7, 2003 | 11:41 AM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
As for motor oil, I agree with Benz, Mobil 1 fully synthetic oil is my choice as well. Go to Mobil 1, click on the link: "Which oil for my car" and enter your specific vehicle info.
As per my mechanic, unless your rear differential is leaking (pretty common), you don't have to worry about changing. If you still would like to change it though, look in your vehicle manual for further info.
About the sunroof, sorry I don't have one so I can't comment on that.
Congratulations on the car and post some pics. if and when you start any mods.
Old Jul 7, 2003 | 11:24 PM
Merc1's Avatar
1998 E320
Got it Done
Thanks All,
Here is what I did, so it may help some people.
1. Changed spark plugs 2 per cylinder total of 12 Bosch
2. Flushed Radiator used MB OEM
3. Chane Brake Fluid MB OEM
4. Motor Oil Mobil 1 0w40 Synthetic took alomost 7.5 Quarts
5. Change differential oil Valvoline 80w90 Durablend reco from MB
6. Change Fuel Filter.
7. Change Air Filter
8. Change Belt
9. Changed Transmission Fluid OEM MB
All this took less than 1 1/2 hour
10. Bought Cabin Filter, couldnt find the Location
11. Bought Cables for Sunroof, that is going to be interesting project.
12. Change new mats.
13. Reset the FSS thanks to E KLASSE for his e mail
Total Parts $298 not including Mats $77 2 Sunroof cable $30each.
AM I MISSING ANYTHING?
Just need to fing the location for cabin Filter.
Again thanks for all of your input, and I hope this info helps other.
Old Jul 8, 2003 | 12:13 AM
Merc1's Avatar
1998 E320
Ok... Here is the method for changing cabin filter:
There are EIGHT screws to remote the glove box. There are 4 that are clearly visible in the upper right and left sides of the front of the glove box. There are 2 that are on the "floor" of the inside of the glove box that are covered by plastic covers. And finally there are 2 more on the "ceiling" of the inside of the glove box that require a short screwdriver to get to. All screws are phillips head.
So I take all eight screws off and with one hard tug I snapped the glovebox out. The filters were VERY dirty and there were about 200 pine needles all over the place back there. BLAH!!! I got the parts from my local dealership, both filters come in a package. Price was like $18.50 since my friend works at a repair shop.
I slid the filters in and that was that.
I found this info on the other board.
Good luck
Old Jul 8, 2003 | 12:24 AM
E-Klasse's Avatar
W205 C300
I was going to reply to you that they were behind the glovebox. Thanks for the description on how to change them. They must have been the original ones. The pine needles didn't give you that fresh pine smell?
Sounds like you should be good to go for a while with all of the work you had done.
Welcome to the Mercedes Family.
