2000 MBZ E320 ABS Shutdown Engine
Old May 10, 2012 | 01:36 PM
Autolizer/MB's Avatar
97 S-320 MBZ, 00 E-320
ABS & Components Flash and automatically shutdown engine within 7 miles, then waited 1/2 hour to re-start the engine. it will run at least 7 miles ABS flash and shutdown the engine again. Whats the problem, the parts,and location? Any help.Thanks
Old May 10, 2012 | 03:26 PM
ohlord's Avatar
Replace your
crankshaft position sensor. See diy on http://www.benzworld.org/forums/w210-e-class/
in the diy section warning lights from stalling and restart possible afer a period of cool down are symptoms of cps failure.
And the answer is no to the idiot that will no doubt chime in and say you will always get a check engine light with a failing cps. He already knows who he is,since he was banned from such moronic comments on another Mercedes forum of some renown
