snap on solus?
searching around the net some, i havent been able to come up with the proper 38 pin connector for the scanner. not sure it exists.
thanks in advance.
FIY if you want the Solus to work on your car(for ENGINE, TRANS, AIRBAG, CLIMATE CONTROL, INSTRUMENT) first you need to make sure that your mechanic has European software installed and also has Keys for Euro cars(ex S64), then you'll need the MB-1 adapter(EAA0355L62A), which you can buy directly from Snap-On for about $50.
Good luck.
If you have access to the scanner you can simply select your vehicle and module you want to access, and it'll tell you which adapter to use.
Now technically some of the wires in OBD II connectors are the same as in the 38pin one. So if you can map out both Snap-On MB-1 and DL-16A and verify that with the Key required both adapters would connect you to the same wires, it could work. But if you end up connecting to the wrong wires you could potentially damage the scanner and/or vehicle.
I use my snapon scanner (the brick) on my wife's 01 and my 02 w210 using the mb-1 connector, the obd2 connector is good for engine but when it comes to trans or body it is very slow and sometimes no communication.
