Garage Door Opener Question (Part 2)
1 Post
2008 Subaru Legacy GT Limited
Okay, so after asking here about programming the garage door opener, I managed to get it done.
However, I'm having one additional issue: it only works inside -- i.e., I can use it to open the garage door when leaving, but when I come back, it won't open from the outside. Any ideas on how I can boost the transmitting power of the door opener?
TIA...
TIA...
Where is the receiving antenna on the garage door opener. I haven't heard of not having enough transmission power. Do other remotes work farther away from the outside?
1 Post
'04 Silverado Z71 - sold all my Benzes and need another!
I agree, if it will work from the inside and when you are leaving and the door is open, it should work from the outside. E-Klasse is right, check the antenna wire on top of the actual garage door openning unit and make sure that it isn't cut or tangled up anywhere...
1 Post
Interestingly, the regular remote works fine; it's when the door is closed and I'm approaching that the integrated remote on the mirror doesn't work.
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
