Sunroof problem (ive read everything on it!)
If you are missing the emergency crank, the drive screw takes 4mm allen wrench. Remove left light cover to access. Lots of torque is needed since you must overcome the mechanical advantage of the motor gear train.
my sunroof will tilt open and shut just fine......when i try to slide it open/back it grinds and crunches as other owners have experienced.....cables mangling i suppose? Anyway, It will move back about an inch and, if i stand outside the car while my son trys the open switch i can move it back another inch but thats it......
after reading about the manual crank i tried that but still no joy......wont budge past the couple inches.......is there any hope other than removing the headliner/unit?
