1998 E300 TD radiator fan did not go into high speed
One thing for sure is that diesels run cooler than gassers and although you may have a fan clutch problem, I believe there are other things going on within the cooling system to cause your problem, possibly a bad thermostat-----and that is were I would start.
PS: also use the correct fluid, not the pink or green crap!!
THinking out loud, I guess if the thermostat stuck again half way, there may not be enough heat going thru the sensor? to trigger increase in fan speed?
