LAMP DEFECTIVE warning!!! HELP
Old Jul 25, 2012 | 02:58 PM
vishanthram's Avatar
2007 SL550
Exclamation LAMP DEFECTIVE warning!!! HELP
Hey guys, i own a 1999 Mercedes E430 classic. I have owned it for about 8 months. Since last week i have getting this "LAMP DEFECTIVE" warning below the speedometer. I parked my car turned on ever single light in my car (inside and outside) and did a visual inspection. I couldn't see any died out bulb. I did notice that my rear, left side turn signal light was emitting just a faint light and so i took it to my car dealership and asked them why and they gave me a MB replacement bulb for free. They replaced it and that light is good now. But still i get the warning when i turn on any outside lights of the car and when i turn off the car. I do not know what to do. Please help me out. Thanks in advance.
Old Jul 25, 2012 | 09:39 PM
4XFORE's Avatar
1998 E320 / 1992 LandCruiser / Project Car E30, 91, 318I
Check your license plate bulb.
Old Jul 25, 2012 | 11:20 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
+1 on license plate light (2 bulbs!).
Intermittent lamp warnings are fairly common on W210s. Often the left rear tail/stop assembly is a problem. MB uses a design which doesn't require wires attached to the socket. Instead the socket makes contact via metal tabs on the housing. Sometimes just rotating the socket slightly will make better contact.
Old Jul 29, 2012 | 04:17 AM
2007 SL550
Talking Thanks
Thanks you guys for your help and as you all said it was the lisence plate light bulb. My usual auto shop gave me the replacement bulb for free. Now the problem is fixed. Thank you so much for you replys!!!
