unlock switch on dash not responding
Old Jul 17, 2003 | 12:37 AM
bostonbob's Avatar
2000 E320 4Matic
Suddenly the switch on my dash that unlocks my doors does not work. Seems like the locks are trying to open but no actual movement. Suggestions?
Old Jul 18, 2003 | 09:33 PM
bostonbob's Avatar
2000 E320 4Matic
update...
Now I've discovered that the locks unlock ONLY if the engine is turned off. Is this how this switch is supposed to work?
Old Jul 18, 2003 | 09:38 PM
livetodrive's Avatar
2001 E-430 4-Matic
Locks
The locks operate regardless of engine operation.
Old Jul 20, 2003 | 12:31 PM
apl175's Avatar
Is other equipment which utilizes pneumatic services working normally on your car? (rear head restraint release, orthopaedic seating, trunk release, etc.)
I think the switch sends a CAN signal to the Pneumatic Services Equipment - so the problem might not be the switch if it's working consistently when the engine is off.
On W210 cars, the PSE unit is located under the rear seat.
Old Jul 21, 2003 | 07:07 AM
bostonbob's Avatar
2000 E320 4Matic
Other equipment that uses PSE works fine. Still very puzzled that lock/unlock switch won't work with engine running - but does work with engine turned off...
