change of idle speed between 'P' and 'D' position
Old Sep 22, 2012 | 06:40 AM
kepez's Avatar
e320 m112 1997
one should expect that idle is same between 'P' and 'D', but mine changes considerably, whatever part is responsible for keeping idle speed constant it is malfunctioning or not functioning at all. does anyone have an idea?
Old Sep 22, 2012 | 10:11 AM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
It should be a little lower in D. The engine is under load then, heating up trans oil while your foot is on the brake. What is the rpm difference?
Old Sep 22, 2012 | 11:28 AM
kepez's Avatar
e320 m112 1997
difference is at least 200rpm, i also realize a surge of power when pulling up from stand still, that occurs somewhere between 2nd and 3rd gear.
