Reverse.
Old Oct 7, 2012 | 11:12 PM
bullpinn's Avatar
mercedes 96 e320
Reverse.
96 E320 wont go in reverse and reverse lights not working....When shifted into reverse it acts as if it might go into reverse, but does not....need help....Is this a rebuild?????
Old Oct 8, 2012 | 11:33 AM
cm60k's Avatar
Originally Posted by Plutoe
I would put the car on a lift and inspect the shifter linkage and bushing first!!
Good Advice...,,
Bad linkage bushings responsible about that acts most of times,,
If you replacing the bushings, and the reverse light still not working, shifter selector switch should be replaced......
Size:  6.3 KBName:  images x1.jpg
ZAYED,,
Old Oct 8, 2012 | 08:37 PM
bullpinn's Avatar
mercedes 96 e320
Originally Posted by cm60k
Good Advice...,,
Attachment 244927Attachment 244928
Attachment 244929
ZAYED,,
Thanks for the info...having it checked tomorrow....thank you a million once again.....Estimated price for that...and is it a DIY.....
