2002 E320 FRONT FOG LIGHT PROBLEM...
e320
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
When I switch on front fog light I get a lamp indicator on dash....Car is on low beam.. Fog lights checked out OK with ohm meter, fuse 15A is good. I need some advice how to continue checking. Thanks for any help with this problem....
D.Wongsam
D.Wongsam
e320
The lamps are Philips 122S8 55 Watts (original ) ... I found the problem, which happens to be a loose pin in a P&J connector... I will try and find the name of the connector and post it on the forum.... Thanks again
D.Wongsam
D.Wongsam
