96 E320 Transmission Question
Hi Folks,
When the engine is cold, for example, overnight or sitting for eight hours at work, the transmission shifts from second to third at 3K RPMs. It does this only the first 2 -> 3 shift. Any ideas what may be causing this?
Any info is appreciated.
Martin
Martin
E300TD (98)
My first port of call is always pull the battery and fully charge it to eliminate that as a cause. Also it would be usefull to measure voltages and give details of which autobox your car has.
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
The only delayed shift when cold is the 1-2 shift to warm up the catalytic converters more quickly. Under the same conditions at what RPMs does it shift from 1-2 and 3-4?
