Bigger wheels=no cruise control??
Old Nov 11, 2012 | 01:27 PM
midnightsaint's Avatar
2001 E320 4matic Estate
I put my 19" wheels on and now my cruise does not work above 70 mpg.
Has anyone had this happen and how do a fix it?
Old Nov 11, 2012 | 05:31 PM
illest's Avatar
w210 AMG or S213
are they staggered?
Old Nov 11, 2012 | 05:35 PM
giuseppesalvato's Avatar
E220cdi avantgarde
cruise control is speed related, it is fixed to the rotanional speed of your wheels, the bigger your wheels, the greater the circumferance, hence the greater distance covered in one rotation, which puts it out of sinc with your cruise control. you need to put the original wheels back on for your cruise control to work properly.
Old Nov 11, 2012 | 10:09 PM
raymond g-'s Avatar
99 E320
i dont think this is entirely the case. you can have larger wheels, larger tires,
but the deal breaker will be rotational difference of more than 2% between front
and rear and it will throw the computer off, thus disengaging the cc.
after all, folks have successfully moved up from 16" rims to 17, to 18, to 19 and
the cruise function has remained intact.
Old Nov 12, 2012 | 02:11 PM
E220cdi avantgarde
thanks for that, that's something else i have learn'nt today.
Old Nov 12, 2012 | 09:16 PM
raymond g-'s Avatar
99 E320
95% of what I learned came from the forums. the rest came from first
hand knowledge and through testing items myself.
Old Nov 13, 2012 | 09:06 AM
Raymond, that what we thought. But I switched to the same size wheel and tire(no more stagger) last week. It did not correct it.
Wheels are 19x9 with 225/35/19 tires front to rear. The cruise works until 70 Mph and then stops.
Old Nov 13, 2012 | 01:41 PM
E220cdi avantgarde
I wonder if the ECU has to be reset to account for wheel size ???.
Old Nov 13, 2012 | 02:50 PM
renault12ts's Avatar
W215 CL500 2005
No.
Are all your tyres the same age...or is there a difference between front and rear.
When my rear tyres were badly worn the CC would kick at about 70mph.
Old Nov 14, 2012 | 12:08 AM
raymond g-'s Avatar
99 E320
what was the exact sizing before and after?
aside from that, the peachparts tech section comes this info
i'll measure mine this weekend
Old Nov 14, 2012 | 03:51 AM
W215 CL500 2005
225/35 19 tyres are 2mm smaller in diameter than the standard 215/55 16 tyres. This difference is absolutely insignificant.
Tyre size is not the problem here.
Old Nov 14, 2012 | 10:29 AM
I think you guys cleared it up and one of the guys at worked help. My front tires have been on for a year now. The rear(the new tires to match the front) are also a different brand. After taking a measurement the fronts are smaller than the rear. By 1/2 of and inch!! So this is the reason. After the first of the year ill match the front and rear.
Thanks for the help guys.
Old Nov 14, 2012 | 12:05 PM
W215 CL500 2005
I was glad to help.
Old May 20, 2019 | 03:53 PM
Will Hart's Avatar
2000 S430
I have the same problem. I have 255/40/18 fronts and 255/45/18 on the rear. Of course for that reason, CC doesn't work. Is there anything I can do or bypass to get it to work? I'm not afraid of ripping out a sensor or something, but I'm not where I can just buy new tires.
Old Jun 3, 2019 | 04:38 PM
scorp_za's Avatar
W164 ML320, W212 E400
Hi Will,
Cruise Control uses your ABS wheel speed sensors, disconnecting these will render your ABS and ESP inoperable. The only fix really would be to match the tyres.
