2000 CLK wheel on 98 w210
2000 CLK wheel on 98 w210 (e320)
Hi,
Can some one tell me if this is possible.
I have 2000 Clk 16" rim with offset of 37
I am trying to put them on 98 w210 16" with offset of 41.
Also, I am reting to put my existing tires on the 2000 clk rim 205/55/16
Can I use existing BOLT from 98 w210 or do I need to change the bolt. Please let me know what I need.
Thanks in advance.
Hi,
Thanks in advance.
The offset and width of the CLK rims will work on your W210. I am not sure about the lugs bolts though. I would compare the CLK lug bolt vs. the stock E lug bolts. The E lug bolts might be the extended type that my not fit the CLK wheel.
But most importantly, which every lugs you ultimately use, check the fit on the rear. Make sure when you bolt up the wheel, you turn the wheel all the way around to ensure the lug bolts are not interfering with the parking brake assembly. If you have both wheel off at the same time, you can visually check how far the lug bolt protrudes out of the wheel.
