e420 brake pads
Is it normal for brake pads to wear-out after ~15K miles? Could it just be the brake light indicator is malfunctioning?
I spoke to a repair shop specializing in Mercedes and was told that Mercedes always changes the shoes AND discs together in order to insure optimal braking performance. Is this correct or just a sales pitch to increase the costs?
If I need new front brake pads and rotors/discs, approximately how much should it cost?
Sorry for all the questions. Thanks in advance for the help!
rcd
As for your rotors, if they are only 15K miles old and they are not vibrating, I would not do anything to the rotors. If they are vibrating I would replace them. It is almost as cheap as turning them, and the results will usually be better.
If your rotors are not warped and can still be turned then you don't need to replace them. If you have been in a lot of stop and go traffic, your pad would wear out faster. Some pads are softer than others and wear out quicker too. I think rotors are $55 each, sensors are $3 each and a set of pads are $45 but you might be able to find them cheeper. Try looking on www.importeccatalog.com .
The pad price...is that per wheel?
And how many sensors are involved? I'd like to do this myself next time (and save $300 on labor), but I have no idea how to replace sensors.
15Kmi sounds pretty fast to wear pads out, but at about 40Kmi, i found that my right front caliper was frozen, the inside pad wore out until it shorted the sensor, the outside pad still had 1/2 thickness. Make sure nothing is frozen.
Rob Lee
hpilot - That very interesting, I've read other posts to indicate that the front pads on a W210 wore out before 20Kmi. When yours wore out, wear the pads worn down to the point wear the "brake lining" warniing came on?
